Wohlgemerkt, er fährt mit nem CT9 Lader und 250 Ps
Tsukuba HotlappingUKSC hat geschrieben:
EP91 turbo At 1999 Tsukuba circuit marking 1 minute 4 seconds 867
Engine itself
4E−FTE base
Forging piston original lightweight [baruburihuta] piston and connecting rod balance taking
Deviation prevention process blow-by gas prevention processing inside oil pan
Turbine air cooled conversion processing
Trust 10 step oil cooler kit
JAM original preface [intakurakitsuto]
Blow off valve less
NGK plug cord
NGK racing 8th plug
The control with JAM original CPU
Turbine
Genuine reforming high flow
Strengthening actuator
[torasutopurohuetsuku] B specifications installation
Exhaust type
JAM original catalyst extension
JAM original TYPE2 muffler
Drive system
Mission itself normal
Only final 4.058
AP racing twin plate clutch
TRD mechanical cable type 1.5WAY LSD
Brake
Front carry per Will Wood 4POT carry per
4POT private brake pad
Rear JAM original type RC brake pad
AP racing adjustment type proportioning valve
APP stain mesh brake line
Suspension bushes
Front
The Cuzco camber adjustment type pyro upper mount
Height pitch for TRD race/lace
Series-wound coming spring 14K for TRD race/lace
Rear
TRD strengthening upper mount
Series-wound coming spring 12K for TRD race/lace
TRD suspension bush
TRD strengthening engine mount
JAM original pyro lateral rod
Interior
[buritsudojigu] you [hurubatsuketoshito]
3 inch [uiranzu] 4Ãâ€â€4 seat belts
[kusukokuromoriroruba] 7 point system
Trust 60Æboost gage oil temperature gauge
Jam Glanza Tested by Keiichi Tsuchiya
now with that same power and setup it did a 1.02.886 seconds around Japans Tsukuba circuit.
food for thought here are some times of stock cars for comparision. it would put it next to this little lot
Nismo Skyline GT-R Z Tune 1 min 01.150 secs
Ferrari 360 Challenge Stra' 1 min 02.440 secs
Jam Glanza 5e hybrid ct9 1 min 0.2.886 secs
Lamborghini Gallardo 1 min 03.605 secs
Honda NSX-R 1 min 03.920 secs
McLaren F1 1 min 04.620 secs
Porsche 997 Turbo 1 min 04.730 secs
Murcielago 1 min 04.760 secs
Z-Tune 1 min 05.100 secs*(diff day diff driver)
EVO IX RS 1 min 05.528 secs
997 Carrera 4 1 min 05.980 secs
Corvette Z06 1 min 06.020 secs
zum schluss noch erwähnenswert diesen wagen gibts für schlappe 2,7 mio Yen zu erwerben
